Salta al contenuto principale
2005-2007 Ford Focus Spark Plugs Replacement
Cosa ti serve
  1. 2005-2007 Ford Focus Spark Plugs Replacement, Spark Plugs: passo 1, immagine 1 di 1
    • Use compressed air to clear any debris from the area around the ignition coils on top of the engine.
    • Any particles that fall into the ignition cylinder could cause serious engine damage.
  2. 2005-2007 Ford Focus Spark Plugs Replacement: passo 2, immagine 1 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 2, immagine 2 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 2, immagine 3 di 3
    • Remove the ignition coil electrical connector by first depressing the plastic tab on top of the connector.
    • Pull the connector straight away from the ignition coil to detach it.
    • Repeat this procedure for the remaining three ignition coils.
  3. 2005-2007 Ford Focus Spark Plugs Replacement: passo 3, immagine 1 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 3, immagine 2 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 3, immagine 3 di 3
    • Use an 8 mm deep socket to loosen the four ignition coil mounting bolts.
    • Once the bolts are loose, they can be removed by hand.
  4. 2005-2007 Ford Focus Spark Plugs Replacement: passo 4, immagine 1 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 4, immagine 2 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 4, immagine 3 di 3
    • Twist the ignition coil and spark plug boot while lifting it straight up to remove it from the engine.
    • Avoid rocking the coil and boot side-to-side, since this could break the existing spark plug.
    • The procedure to remove the ignition coil and spark plug boot is the same for each spark plug. However, to reduce the chance of dirt entering the engine, only remove one at a time.
  5. 2005-2007 Ford Focus Spark Plugs Replacement: passo 5, immagine 1 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 5, immagine 2 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 5, immagine 3 di 3
    • Use a ratcheting socket wrench with an extender and a 5/8" spark plug socket to remove the existing spark plug from the cylinder head. Make sure that the spark plug is completely seated in the rubber end of the socket before loosening it.
    • Spark plug sockets have rubber in the end of them to grip the spark plug and are made long enough to keep from snapping the spark plug. There are other common methods for removing spark plugs that involve using a long piece of rubber tubing to pull them out, but using a spark plug socket is the correct procedure.
  6. 2005-2007 Ford Focus Spark Plugs Replacement: passo 6, immagine 1 di 2 2005-2007 Ford Focus Spark Plugs Replacement: passo 6, immagine 2 di 2
    • Apply dielectric grease to the ribbed portion of the insulator.
    • Gently place the spark plug boot over the ribs and twist the two pieces back and forth to even out the layer of dielectric grease.
  7. 2005-2007 Ford Focus Spark Plugs Replacement: passo 7, immagine 1 di 2 2005-2007 Ford Focus Spark Plugs Replacement: passo 7, immagine 2 di 2
    • Place the new spark plug firmly in the spark plug socket so that the threaded end sticks out.
    • Apply an even layer of anti-seize compound to the threads of the spark plug.
    • Be careful not to get any of the anti-seize compound on the spark plug's electrode.
  8. 2005-2007 Ford Focus Spark Plugs Replacement: passo 8, immagine 1 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 8, immagine 2 di 3 2005-2007 Ford Focus Spark Plugs Replacement: passo 8, immagine 3 di 3
    • Place the new spark plug into the cylinder head and tighten it by hand as much as you can.
    • Tighten the spark plugs to 11 ft-lbs with a torque wrench.
  9. 2005-2007 Ford Focus Spark Plugs Replacement: passo 9, immagine 1 di 2 2005-2007 Ford Focus Spark Plugs Replacement: passo 9, immagine 2 di 2
    • Place the ignition coil and dust boot back over the spark plug by pushing down and twisting it into place.
    • Reconnect the ignition coil electrical connector by snapping it back into place.
    • After installing your new spark plugs, compare the old ones to a spark plug wear chart to determine if there are any issues with the way your engine is running. A similar chart can be found in the back of all Haynes repair manuals.
Linea Traguardo
Altre 28 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.882 Reputazione
127 Guide realizzate
11 Commenti
Awesome guide. My Focus is exactly the same, Screaming Yellow! But can you put in a guide to change the air filter too?
rebeccakaise - Replica
I found out that standard-issue air filters for the ‘05-’07 Focus are lifetime 150k-mile filters, and shouldn’t need regular replacement. My parents’ Aerostar also had such a filter, so it may be a regular design feature in Ford vehicles. There’s a little gauge next to the filter housing: if the yellow line is still in the green, then there’s adequate airflow. If it’s in the red region, there’s a problem. I do not know if the car engine has to be on or not, but best check it in both states to be sure.
Madcat221 -
but what if i did what you had shown. an it works for the couple of days an then it starts to bang each time you put it in gears . its like it lose power then it comes back on.. have a ford focus 4cyl 2.0 engine
Jose Velasquez - Replica
My focus st does not have power as I have just changed the spark plugs and I used the NGK ones . Are they the correct ones or can u recommend plugs to use .
Regards
Pat
Pat Mokoena - Replica
I have 2007 model Ford focus st and the problem I have started when I changed my spark plugs and now there is no power and can only ďrive oņ 40km per hour.
Please advice if the problem is the plugs as I used NGK or any other problem
Regards
Pat
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 167
Tutti i Tempi: 117,450
