Introduzione
The steps in this guide are used to replace the brake pads on all Focus models in the 2005-2007 generation, except for the ST model, which has slightly different brakes. Caution should be exercised when working with brake and suspension components, and proper safety goggles should be worn at all times.
Whenever working on your car's brakes and suspension, work on one side at a time. Keep the other side completely assembled so that you can reference it at any time.
Never drive a car if the brakes on one side only are changed, because the car will "pull" to one side.
Cosa ti serve
Put the car in park (automatic) or neutral (manual).
Apply the parking brake.
Place chocks behind the rear wheels.
The brake fluid reservoir is located towards the back of the engine compartment.
Unscrew the cap and remove it.
Place the cap back on the brake fluid reservoir.
Turn the key to the "on" position. Press the brake pedal a few times. It should go to the floor once, and then become firm.
Fill the brake fluid reservoir with new fluid, if needed.
Replace the brake fluid reservoir cap, close the hood, and lower the car.
Altre 24 persone hanno completato questa guida.
8 Commenti
Excellent guide --- many thanks ! Also applicable with virtually no modifications to my 2012 Ford Ikon, except that on my car the guide pins needed a size 45 Torx bit to unscrew. I had to replace the rotors as well, and discovered Ford had used threadlocking compound on the mounting bolts for the bracket, making them the devil to remove without pneumatic wrench. Threadlocking compound should be outlawed !!
GEB
Awesome guide. Very helpful. No trouble at all.
Top effort… just saved myself £25!
