Salta al contenuto principale
2005-2012 Toyota RAV4 Headlight Replacement
  1. 2005-2012 Toyota RAV4 Headlight Replacement, Headlight: passo 1, immagine 1 di 1
    • Turn off your car, use your emergency break to secure the car and pop open the hood.
    • Make sure the engine is not hot before working under the hood of the car.
  2. 2005-2012 Toyota RAV4 Headlight Replacement: passo 2, immagine 1 di 2 2005-2012 Toyota RAV4 Headlight Replacement: passo 2, immagine 2 di 2
    • Under the hood of the car, locate a black cable towards the grille on the drivers side that leads to the back of the headlight. The bulb is located here.
  3. 2005-2012 Toyota RAV4 Headlight Replacement: passo 3, immagine 1 di 3 2005-2012 Toyota RAV4 Headlight Replacement: passo 3, immagine 2 di 3 2005-2012 Toyota RAV4 Headlight Replacement: passo 3, immagine 3 di 3
    • Turn the bulb counter-clockwise using your hand and gently pull the headlight out.
  4. 2005-2012 Toyota RAV4 Headlight Replacement: passo 4, immagine 1 di 2 2005-2012 Toyota RAV4 Headlight Replacement: passo 4, immagine 2 di 2
    • The headlight is attached to a plug that has a clip. Push down on the clip and pull the bulb out at the same time with the opposite hand.
  5. 2005-2012 Toyota RAV4 Headlight Replacement: passo 5, immagine 1 di 3 2005-2012 Toyota RAV4 Headlight Replacement: passo 5, immagine 2 di 3 2005-2012 Toyota RAV4 Headlight Replacement: passo 5, immagine 3 di 3
    • Slide the new bulb into that same plug until you hear a click.
  6. 2005-2012 Toyota RAV4 Headlight Replacement: passo 6, immagine 1 di 2 2005-2012 Toyota RAV4 Headlight Replacement: passo 6, immagine 2 di 2
    • Put the bulb into the same hole that it was removed from and turn clockwise until you hear another click. You are done!
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
This is a headlight BULB replacement, not a headlight replacement. Please consider changing the title, which is misleading. Thank you.
Barb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 83
Ultimi 30 Giorni: 413
Tutti i Tempi: 7,396
