Introduzione
An oil change including installing a new filter is a service that should be completed around every 5000 miles to ensure that the engine is properly lubricated and can run smoothly.
Cosa ti serve
Jack up the car using the car jack.
Be sure to place the car jack under the proper reinforced areas.
The reinforced area is located just behind the front wheels, between two bumps in the undercarrage frame.
Reference the car's manual if you require more information on how to safely jack up your car without damaging the frame.
Unscrew the yellow oil fill cap using your hands.
Wait a couple minutes for the oil to settle at the bottom of the oil pan.
Using the dip stick, ensure the oil level is within the recommended range.
Start the car.. Oil will fill the filter and once your turn the car off you will see you need to add a little more than 3.7qts
Wipe off the dipstick before to remove any excess oil on it.
Put the dipstick back in the dipstick hole in the engine bay and push it all the way down.
Pull the dipstick back up and look at where the oil line is with respect to the markings on the dipstick.
The low oil line is the lower raised line on the dipstick, and the high oil line is the higher raised line. You want the oil level to be in between the two.
If the oil level is too low, add more clean oil into the oil fill spout. If the oil level is too high it may be necessary to drain the oil and repeat the guide over again to avoid engine damage from excess engine oil.
Altre 5 persone hanno completato questa guida.
