Salta al contenuto principale
2004-2008 Mazda RX-8 Air Filter Replacement
  1. 2004-2008 Mazda RX-8 Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Begin by opening the hood of the vehicle and locating the air filter cover.
    • The air filter is located in the middle of the front of the vehicle covered by a large black rectangular cover.
  2. 2004-2008 Mazda RX-8 Air Filter Replacement: passo 2, immagine 1 di 3 2004-2008 Mazda RX-8 Air Filter Replacement: passo 2, immagine 2 di 3 2004-2008 Mazda RX-8 Air Filter Replacement: passo 2, immagine 3 di 3
    • Locate the two tabs on either side of the front of the air filter cover. Grab and pop open these two tabs.
    • Push the air filter cover open with your fingers. The air filter will now be visible and begin to pop up.
    • Once the air filter pops up, you can grab it with your hands and begin to remove it from the cover that is still being held open.
  3. 2004-2008 Mazda RX-8 Air Filter Replacement: passo 3, immagine 1 di 2 2004-2008 Mazda RX-8 Air Filter Replacement: passo 3, immagine 2 di 2
    • Gently pull the entire air filter out of the opened cover. This might take more than one set of hands in order to keep the cover open during removal.
    • The air filter is now fully removed and outside of the air filter cover. Obtain a new air filter to replace the old one.
  4. 2004-2008 Mazda RX-8 Air Filter Replacement: passo 4, immagine 1 di 3 2004-2008 Mazda RX-8 Air Filter Replacement: passo 4, immagine 2 di 3 2004-2008 Mazda RX-8 Air Filter Replacement: passo 4, immagine 3 di 3
    • Pry apart the cover of the air filter again to begin inserting your new air filter.
    • Gently push the new air filter back into the opened air filter cover the same way you removed it. The air filter will fall back into its resting position.
    • Once the new air filter has been fully inserted into the cover, close the cover and push the two tabs on the outside of the cover closed.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 8-4, Regan Spring 2015 Membro di Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,080
