Salta al contenuto principale
2004-2013 BMW 3 Series Inner Taillight Replacement
Cosa ti serve
  1. 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: passo 1, immagine 1 di 2 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: passo 1, immagine 2 di 2
    • Unlock your trunk.
    • This can be done with either the remote or the trunk release button located on the driver's side footwell area.
    • Using the trunk handle, lift the trunk to it's highest position.
  2. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, immagine 1 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, immagine 2 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, immagine 3 di 3
    • Using the appropriate trim tool, carefully remove all ten rivets from the trunk liner.
  3. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, immagine 1 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, immagine 2 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, immagine 3 di 3
    • Pull on the green tab to release the inner trunk release handle.
    • After this, the trunk liner should be loose.
    • Carefully remove the liner and put it off to the side for later reassembly.
  4. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, immagine 1 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, immagine 2 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, immagine 3 di 3
    • Using either a 10 mm socket or an open-end 10 mm wrench, turn the nut counterclockwise to loosen it and remove the bracket that secures the inner taillight.
    • An open-end wrench was used in this guide, however, both tools work for removing the retaining nut.
  5. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 5, immagine 1 di 2 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 5, immagine 2 di 2
    • From underneath the inner taillight, push the housing with enough upward force to separate it from its socket.
    • Be careful when pushing the housing, as the connector is still attached to the inner taillight.
  6. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, immagine 1 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, immagine 2 di 3 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, immagine 3 di 3
    • Tilt the inner taillight enough to gain access to the connector on the underside.
    • Firmly press the locking tab in the center of the connector.
    • Pull downwards on the connector to disconnect the inner taillight housing.
  7. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 7, immagine 1 di 1
    • Prepare your new taillight for reassembly.
    • Responsibly recycle your old inner taillight if it is no longer functional.
Conclusione
To reassemble the inner taillight, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 94
Tutti i Tempi: 284
