Salta al contenuto principale
2003 Chevrolet Cavalier Engine Air Filter Replacement
Cosa ti serve
  1. 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 1 di 2 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 2 di 2
    • Pull the hood release lever.
    • This lever is located inside the cabin of the car to the left of the pedals.
  2. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 2, immagine 1 di 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 2, immagine 2 di 2
    • Pull up on the hood slightly and lift the safety latch.
    • The hood will not open unless the safety latch has been lifted.
  3. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 3, immagine 1 di 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 3, immagine 2 di 2
    • Open the hood and hold it with one hand.
    • Grab the prop rod in the other hand.
    • Insert the prop rod into one of the slots in the hood to secure it in place.
    • Make sure the prop rod is secure in the slot otherwise the hood may fall.
  4. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 4, immagine 1 di 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 4, immagine 2 di 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 4, immagine 3 di 3
    • Unclip the wiring harness from the retaining clamps with a flathead screwdriver.
    • Pull the wiring harness out of the clamps.
  5. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 5, immagine 1 di 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 5, immagine 2 di 2
    • Unscrew the four cover-mounting screws holding the air filter cover on.
    • The screws do not come out of the filter housing.
  6. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 6, immagine 1 di 1
    • Separate the housing halves to access the air filter element.
  7. 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 7, immagine 1 di 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 7, immagine 2 di 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: passo 7, immagine 3 di 3
    • Remove the old air filter.
    • Place the new filter in the housing.
    • The new air filter will sit comfortably in place without wobbling.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 105
