Salta al contenuto principale
2003-2007 Honda Accord Spark Plugs Replacement
Cosa ti serve
  1. 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: passo 1, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: passo 1, immagine 2 di 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
    I change my oil every 5.000 miles like clockwork I did a compression test a few weeks ago and it's only lost about 2% of it compression and done 160.000 miles so well worth it
    Graham Wells - Replica
    What if u can’t get inside to unlock the hood
    Paula Charron - Replica
    My fob is not working properly I guess I checked the battery and it’s good still won’t open car a Sonata hybrid 2021 what do I do?
  2. 2003-2007 Honda Accord Spark Plugs Replacement: passo 2, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement: passo 2, immagine 2 di 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Spark Plugs Replacement: passo 3, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement: passo 3, immagine 2 di 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: passo 4, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: passo 4, immagine 2 di 2
    • Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place.
    • Lift the plastic cover and set it aside.
    You may need to use a wrench if your screws get separated from the bottom part under the spark plug cover.
    Craig Mendonca - Replica
  5. 2003-2007 Honda Accord Spark Plugs Replacement: passo 5, immagine 1 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 5, immagine 2 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 5, immagine 3 di 3
    • Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
  6. 2003-2007 Honda Accord Spark Plugs Replacement: passo 6, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement: passo 6, immagine 2 di 2
    • Use a 10 mm hex driver or socket to remove the four spark plug boot screws.
  7. 2003-2007 Honda Accord Spark Plugs Replacement: passo 7, immagine 1 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 7, immagine 2 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 7, immagine 3 di 3
    • Lift the boot screws out of the spark plug bores.
  8. 2003-2007 Honda Accord Spark Plugs Replacement: passo 8, immagine 1 di 2 2003-2007 Honda Accord Spark Plugs Replacement: passo 8, immagine 2 di 2
    • Locate the spark plug at the bottom of the bore.
    • Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
    what length of socket extension needed for 2005 honda accord
    Parimal - Replica
    Place duct tape on the inside of socket if the spark plug isn’t held when trying to pull it up. Also, tape the socket to the socket extension to ensure that it doesn’t fall into the bore.
  9. 2003-2007 Honda Accord Spark Plugs Replacement: passo 9, immagine 1 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 9, immagine 2 di 3 2003-2007 Honda Accord Spark Plugs Replacement: passo 9, immagine 3 di 3
    • Pull the plug out of the bore.
    Référence de la bougie svp
    ABROUS AHMED - Replica
    Do you need to check ignition coils for each cylinders for tune up
    Julius Tomlin - Replica
  10. 2003-2007 Honda Accord Spark Plugs Replacement: passo 10, immagine 1 di 1
    • Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • The gap is bridged by corrosion.
    • The gap is too large.
    • The area around the gap is black and dark.
  11. 2003-2007 Honda Accord Spark Plugs Replacement: passo 11, immagine 1 di 1
    • If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • Use of Anti-Seize on the thread of spark plug is highly recommended to ensure threads don't get damaged while tightening.
    • Use a ratchet, extension, and 5/8 inch socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
    • If a torque wrench is available, tighten to 13 ft-lbs.
    • Repeat Steps 10-13 for the three remaining spark plugs.
    Can I tighten the spark plug properly without a torque wrench?
    Parimal - Replica
    You can get a torque wrench at Harbor freight for less than $20 and if you are a do-it-yourself person you will need this for every mechanical job you do. Lawn equipment,automobiles , or anything that uses machined parts you will always need a torque wrench. They will last a lifetime if you clean it and zero it after every job.
    Bob Wilson -
    Denso specifically states in their spark plug manual that thread lubricant should not be used due to potential overtightening resulting to seal leakage.
    Erno Pentzin - Replica
Conclusione
After reinstalling all four spark plugs, follow Steps 3-9 in reverse order to reattach the spark plug cover and close the car's hood.
Altre 36 persone hanno completato questa guida.
Cal Poly, Team 24-27, Regan Fall 2012 Membro di Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membri
22 Guide realizzate
7 Commenti
Great instructions! I was able to change them pretty quickly.
JOEL DENNIS - Replica
First rule of thumb when changing spark plugs is to do it when the engine is cold. If you don't have a torque wrench it's ok, you can still tighten them properly. Easiest thing to do is put the new plug in the spark plug socket, attach the extension (8 or 10 in. is perfect) but not the ratchet. Thread the plug in until it is snug, then attach the ratchet to tighten. Most spark plug manufacturers put on the box (especially NGK) how much to tighten. Usually if the plug has no gasket, tighten 1/16 to 1/8 of a turn. If it has a gasket, tighten 1/2 to 2/3 of a turn. For an '05 Accord 4 cyl. they have a gasket.
wingmaneh - Replica
Thanks for the clear instructions & photos!
Steve T - Replica
I appreciate the thorough and precise instructions. I would add using anti-seize on new plug threads.
ssnider727 - Replica
On an '05 Accord, are there any wires that need to be replaced at a regular interval?
Ryan Roux - Replica
All Done With Absolutely No
Clyde Dobbins - Replica
Is there ignition coils in each cylinders on the 2005 Accord
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 419
Tutti i Tempi: 99,474
