Salta al contenuto principale
2003-2007 Honda Accord Interior Door Handle Replacement
Cosa ti serve
  1. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: passo 1, immagine 1 di 3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: passo 1, immagine 2 di 3 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: passo 1, immagine 3 di 3
    • Open the appropriate side door of your vehicle that requires a door handle replacement.
    • Locate the tab on the panel behind the door handle.
    • Use a flat-head screwdriver (1 x 3 mm) to move the tab to the right and slightly pull the panel out.
  2. 2003-2007 Honda Accord Interior Door Handle Replacement: passo 2, immagine 1 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 2, immagine 2 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 2, immagine 3 di 3
    • Locate two (2) Phillips head screws behind the door handle.
    • Remove the two Phillips head screws (1.6 x 1.3 x 10.16 mm) using a Phillips head screwdriver (1 x 3 mm).
  3. 2003-2007 Honda Accord Interior Door Handle Replacement: passo 3, immagine 1 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 3, immagine 2 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 3, immagine 3 di 3
    • The first image shows the approximate location of 3 tabs behind the door handle assembly. Knowing the location of tabs is useful when attempting to release assembly.
    • Using your left hand, pull the assembly to the left to reveal the tab on the right. While pulling on the assembly, use a flat-head screwdriver (1 x 3 mm) to press the tab inward to release.
    • Once the tab on the right is released, a slight pull of assembly will release it from the door.
  4. 2003-2007 Honda Accord Interior Door Handle Replacement: passo 4, immagine 1 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 4, immagine 2 di 3 2003-2007 Honda Accord Interior Door Handle Replacement: passo 4, immagine 3 di 3
    • Rotate the door handle assembly for ease of access to clips
    • Locate the first clip holding the door cable.
    • Rotate the clip clockwise to unlock the cable.
    • Once unlocked, pull the cable end from the holder.
  5. 2003-2007 Honda Accord Interior Door Handle Replacement: passo 5, immagine 1 di 2 2003-2007 Honda Accord Interior Door Handle Replacement: passo 5, immagine 2 di 2
    • Locate the second clip holding the door cable.
    • Using a flat-head screwdriver (1 x 3 mm), release the clip.
    • Once the cable is released, the assembly is free to remove.
Conclusione
To install your new door handle assembly, follow these instructions in reverse order.
Additional tips: For step 5, the clip will be pushed back into the clip holder. For step 4, replace the cable and rotate the clip clockwise.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 111
