Introduzione
In this iFixit guide, we will be guiding you through the steps of replacing the interior door handle on a 2003-2007 Honda Accord. Replacing the interior door handle on a 2003-2007 Honda Accord is a task that can significantly improve the functionality and aesthetics of your vehicle's interior.
Whether your handle is broken, damaged, or simply worn out, replacing it can restore the convenience and the ease of accessing your car's interior. In this guide, we will walk you through the steps involved in safely and effectively replacing the interior door handle on your Honda Accord.
Cosa ti serve
Open the appropriate side door of your vehicle that requires a door handle replacement.
Locate the tab on the panel behind the door handle.
Use a flat-head screwdriver (1 x 3 mm) to move the tab to the right and slightly pull the panel out.
The first image shows the approximate location of 3 tabs behind the door handle assembly. Knowing the location of tabs is useful when attempting to release assembly.
Using your left hand, pull the assembly to the left to reveal the tab on the right. While pulling on the assembly, use a flat-head screwdriver (1 x 3 mm) to press the tab inward to release.
Once the tab on the right is released, a slight pull of assembly will release it from the door.
To install your new door handle assembly, follow these instructions in reverse order.
Additional tips: For step 5, the clip will be pushed back into the clip holder. For step 4, replace the cable and rotate the clip clockwise.
