Salta al contenuto principale
2003-2008 Pontiac Vibe Air Fuel Sensor Replacement
Cosa ti serve
  1. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement, Air Fuel Sensor: passo 1, immagine 1 di 2 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement, Air Fuel Sensor: passo 1, immagine 2 di 2
    • WARNING: Hazardous situation which, if not avoided, could result in death or serious injury. Make sure the engine is off!
    • Open the hood and locate the old air fuel sensor.
    • The air fuel sensor is located above the catalytic converter (upstream).
  2. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 2, immagine 1 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 2, immagine 2 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 2, immagine 3 di 3
    • Disconnect one end of the old sensor by pressing the button. The circle in the first image shows the button.
    • The tab can be hard to remove! You may need to use a screwdriver to disconnect it.
    • Listen for an audible click.
  3. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 3, immagine 1 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 3, immagine 2 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 3, immagine 3 di 3
    • Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor.
    • Turn the wrench counterclockwise until the old air fuel sensor detaches.
    • Pull out the old air fuel sensor.
  4. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 4, immagine 1 di 2 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 4, immagine 2 di 2
    • Locate the new air fuel sensor.
    • Locate the tube of anti-seize lubricant that came with the new sensor.
    • Apply the oil lightly to the threads.
    • The oil is named DENSO oil. It will lubricate and provide protection for the threads (circled in the first picture).
    • Use gloves to protect your hands!
  5. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 5, immagine 1 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 5, immagine 2 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 5, immagine 3 di 3
    • Insert the newly oiled air fuel sensor.
    • Tighten the sensor with the O2 sensor wrench.
  6. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 6, immagine 1 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 6, immagine 2 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 6, immagine 3 di 3
    • Connect the tab to the upstream.
    • You will hear a click once the tab is connected to the upstream.
  7. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 7, immagine 1 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 7, immagine 2 di 3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: passo 7, immagine 3 di 3
    • Turn your ignition on.
    • Check your dashboard to see if the check engine light is still on.
    • If the light is still on, turn the car off and wait a few minutes. Then turn the car back on and check the light again.
    • If the check engine light is still on, then use a code reader to see what is wrong with the car.
Conclusione
Erin Rodgers
Membro da: 09/30/21
337 Reputazione
2 Guide realizzate
Un commento
STEP 3 SAYS "Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor." DOWNSTREAM? I thought we were working on UPSTREAM. I'm goin fishing !!!
William Colwell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,452
