Introduzione
This guide shows you how to replace the front CV axle drive shaft on a 2004 Toyota 4Runner 4WD, but will apply to all 4WD and 2WD 3rd Gen 4runners.
Replacement often is required due to a ripped boot and grease leakage, and you'll feel a rough ride. Replacing the entire axle is more cost-effective than just replacing the rubber boots, and is significantly easier.
Cosa ti serve
Panoramica Video
Remove the dust cap from the wheel hub to access the large nut.
Use a 35mm six-point socket to remove the large nut
If your compressor is not working, you can lower the wheel to the ground and use a breaker bar to loosen the nut.
Remove the wheel and check that the CV axle is free and can be moved towards the inside.
Remove the steering outer tie rod by removing the cotter pin and 19mm nut
Use a puller to release the ball joint without damaging the boot.
Carefully separate the CV shaft from the front differential using a pry bar, making sure not to damage any seals.
Gently install the new CV shaft into the front differential, making sure not to damage any seals.
Apply a small amount of anti-seize to the CV shaft before inserting it into the wheel hub.
Use the large nut and 35mm socket to pull the CV shaft all the way into the wheel hub.
Apply blue thread lock to the two large bolts holding the wheel assembly to the lower control arm and tighten them.
Reinstall the wheel and tighten the large nut using a breaker bar
Make sure to use the correct position for the locking pin and secure it with a new cotter pin.
Tap the dust cap back into place using a rubber mallet and a small amount of anti-seize. Now that the new CV shaft is installed, you can reinstall any remaining parts and go for a test drive to ensure everything is working correctly.
Additional Information
- The new CV shafts may come with gold nuts that are too shallow for use with a cotter pin. In this case, reuse the original nut.
