Introduzione
This guide will teach you how to replace the 12V battery in a 2nd-generation Prius. The 12V battery is an essential component of the hybrid car that allows the accessory mode and the hybrid battery system to start up. The 12V battery can be depleted over time or be drained accidentally, making it necessary to replace the battery earlier than expected. When the battery stops working, accessory features such as radio, headlights, and dashboard lights will not start up. Because of the hybrid features of the car, if the 12V battery loses power, the hybrid control system will also stop working, causing error messages and severe safety issues such as braking problems and a switch to gasoline-only driving, which is not intended for this vehicle and will affect driving.
It is a good idea to replace the battery before it is completely drained, with the car often showing early signs such as dimming headlights, flickering car lights, or startup failures.
Before you begin this repair, turn off your car, put it in park with the emergency brake, and make sure that the car has cooled off if it has been driven recently. In addition, this is a large battery so be very careful disconnecting the battery terminal.
Cosa ti serve
Altre 4 persone hanno completato questa guida.
