Salta al contenuto principale
2002 Toyota Tacoma Headlight Bulb Replacement
Cosa ti serve
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 2, immagine 1 di 2 2002 Toyota Tacoma Headlight Bulb Replacement: passo 2, immagine 2 di 2
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 3, immagine 1 di 2 2002 Toyota Tacoma Headlight Bulb Replacement: passo 3, immagine 2 di 2
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 4, immagine 1 di 2 2002 Toyota Tacoma Headlight Bulb Replacement: passo 4, immagine 2 di 2
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 5, immagine 1 di 1
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 6, immagine 1 di 1
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
Conclusione
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Drake Fenwick
Membro da: 02/17/21
133 Reputazione
1 Guida realizzata
Un commento
thank you, saved me alot of time.
harley cortez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,455
