Salta al contenuto principale
2001-2005 Honda Civic Tail Light Replacement
Cosa ti serve
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: passo 1, immagine 1 di 1
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: passo 2, immagine 1 di 1
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: passo 3, immagine 1 di 1
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: passo 4, immagine 1 di 1
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
Conclusione
To re-install a tail light, follow these steps in reverse.
Altre 2 persone hanno completato questa guida.
Tyler Smith
Membro da: 10/23/13
846 Reputazione
3 Guide realizzate
Un commento
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 42
Tutti i Tempi: 8,431
