Salta al contenuto principale
2001-2005 Honda Civic Front Brake Pads and Rotor Replacement
Cosa ti serve
Istruzioni Video
Conclusione
Altre 2 persone hanno completato questa guida.
eCuration
Membro da: 05/19/17
376.693 Reputazione
234 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
2 Commenti
kudos for making the video. The main reason I like to “see” these jobs done is to know what to expect before I start a job. I haven’t seen an impact screw driver in forty years though!
Stephan Eichinger - Replica
Change your video… 80K views for a non-pro... The slots in the surface are for Gas Evacuation; ie: from the resin in the pads. The slotted rotors fins are for cooling. If you are in there for rotors: Why Not pull the pads ( and de-glaze with some emery-paper on a true surface). Pull and lube the sliders and re-anti-seize the pad-backs and clips ? ps: Compress the pistons makes sure they slide. This is basic brake-care and you should get at least two pads sets to one rotor replacement. ps: Don’t learn from me- i ain’t no pro. pps: Me too with a rotor-parts mix-up even after watching the 'Pro's' at SouthmainAuto and Ericthecarguy.
paul rattenbury - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 73
Tutti i Tempi: 13,114
