Salta al contenuto principale
1999-2002 Suzuki SV650 Seat Replacement
Cosa ti serve
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: passo 1, immagine 1 di 2 1999-2002 Suzuki SV650 Seat Replacement, Seat: passo 1, immagine 2 di 2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
Conclusione
Phillip Takahashi
Membro da: 08/22/11
86.704 Reputazione
87 Guide realizzate
Un commento
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 46
Tutti i Tempi: 7,867
