Salta al contenuto principale
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
Cosa ti serve
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: passo 1, immagine 1 di 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 2, immagine 1 di 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 3, immagine 1 di 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: passo 4, immagine 1 di 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 5, immagine 1 di 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 6, immagine 1 di 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 6, immagine 2 di 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 7, immagine 1 di 1
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: passo 8, immagine 1 di 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: passo 8, immagine 2 di 2
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 9, immagine 1 di 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 9, immagine 2 di 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 10, immagine 1 di 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 11, immagine 1 di 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 11, immagine 2 di 2
    • Gently unplug and lift out the automatic transmission control unit.
Conclusione
Altre 8 persone hanno completato questa guida.
Matthew Newsom
Membro da: 01/05/10
39.452 Reputazione
67 Guide realizzate
5 Commenti
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Replica
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Replica
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Replica
thank you very much .
emad_szs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 103
Tutti i Tempi: 43,553
