Salta al contenuto principale
Introduzione
Replace a dirty engine air filter to make your car happy.
Ricambi
  1. Using a vise grip, grip the metal ring securing the intake tube to the air filter cover. Slide the ring up the tube.
    • Using a vise grip, grip the metal ring securing the intake tube to the air filter cover.
    • Slide the ring up the tube.
  2. Unplug the cable from the air filter. Unplug the cable from the air filter.
    • Unplug the cable from the air filter.
  3. Pull the intake tube off of the air filter cover.
    • Pull the intake tube off of the air filter cover.
  4. Unscrew two Phillips screws located behind the air filter.
    • Unscrew two Phillips screws located behind the air filter.
  5. Lift the air filter cover up, starting from the back end, making sure to release them from the hinges on the front end.
    • Lift the air filter cover up, starting from the back end, making sure to release them from the hinges on the front end.
  6. Remove the air filter.
    • Remove the air filter.
Conclusione
Altre 10 persone hanno completato questa guida.
Matthew Newsom
Membro da: 05/01/2010
36.369 Reputazione
67 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 23,852
