Salta al contenuto principale
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
Cosa ti serve
  1. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: passo 1, immagine 1 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: passo 1, immagine 2 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Rear hatch lift supports: passo 1, immagine 3 di 3
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • The rear hatch has both a left and right lift support strut.
  2. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: passo 2, immagine 1 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: passo 2, immagine 2 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Loosen the strut bolts: passo 2, immagine 3 di 3
    • The struts are fastened with T40 Torx head bolts.
    • Use a T40 Torx driver to loosen the bolt
    • The bolt does not remove the strut. It is pressed in to the strut and will be replaced with the new strut.
  3. 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: passo 3, immagine 1 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: passo 3, immagine 2 di 3 1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement, Replace the struts: passo 3, immagine 3 di 3
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This will stop the tailgate from sagging.
Conclusione
To reassemble your Jeep, follow these instructions in reverse order.
Altre 8 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
789.521 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
34 Membri
597 Guide realizzate
4 Commenti
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Raymond Janko - Replica
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
oldturkey03 -
I need to replace the lower bolt as it snapped in half. Any advice for that?
Dave Hankins - Replica
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
oldturkey03 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 40
Tutti i Tempi: 9,995
