Cosa ti serve
First locate the 4 screws to remove the door panel. See pic1
2 screws are visible.
The other 2 screws are behind items.
Location of the screws.
First screw is under the door lock/window controls. See pic 2.
Next screw located lower right of panel behind reflector. See pic 3
After removing screws, Pull on the panel around the outside to release the pop-in clips.
Then remove the panel from the door by lifting up and backward on the panel. Pic 2
On the bottom of the glass inside the door there are two bolts that hold the window to the plastic track on the regulator.
Before you remove the second screw hold the window to prevent breakage of the window.
While holding the window remove the second screw and lift out the window from the door.
Locate and loosen the 4 bolts holding the regulator. See pic 1.
Then remove the window regulator motor and all of the track from the door...
Altre 4 persone hanno completato questa guida.
