Salta al contenuto principale
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
Cosa ti serve
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, immagine 1 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, immagine 2 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, immagine 3 di 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 2, immagine 1 di 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 2, immagine 2 di 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, immagine 1 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, immagine 2 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, immagine 3 di 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 4, immagine 1 di 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, immagine 1 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, immagine 2 di 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, immagine 3 di 3
    • Put back the light housing and screw in the two Philips screws.
Conclusione
Test and enjoy your new LED truck high mount brake/tail replacement lights.
Altre 2 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.357 Reputazione
23 Guide realizzate
2 Commenti
The problem is there are no screws to remove.
richard - Replica
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 5,986
