Salta al contenuto principale
1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement
Cosa ti serve
  1. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement, Door Lock Cylinder: passo 1, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement, Door Lock Cylinder: passo 1, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement, Door Lock Cylinder: passo 1, immagine 3 di 3
    • With the angled screwdriver, remove the door handle trim and the door's plastic trim panel. One more time, with the help of the angled screwdriver, remove the window switch trim panel.
    • Getting under the door lock knob with the screwdriver will help remove the door lock knob.
  2. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 2, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 2, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 2, immagine 3 di 3
    • With the 9/32mm socket, remove the bolt behind the window switch trim panel.
    • After disconnecting the wires with the cross screwdriver, remove the screw behind the door handle.
    • When removing these cables, remember that the power mirror switch has a clip that needs to be pushed to disconnect.
  3. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 3, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 3, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 3, immagine 3 di 3
    • Carefully lift the whole door panel and pull the door panel.
    • In between the door and the door panel, two other wires need to be disconnected as well. Now, the whole door panel separates.
    • The cable towards the top also has a clip that needs to be pushed to detach successfully.
  4. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 4, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 4, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 4, immagine 3 di 3
    • After removing the door panel, find the cylinder door lock and its original location. Carefully place the cylinder door lock back on the slot.
  5. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 5, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 5, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 5, immagine 3 di 3
    • Now that the cylinder door lock is successfully back in place connect the two cables that were removed last. To place the door panel back, ensure the door panel clips and the slots connect. Carefully push down the door panel to secure the door panel in place.
  6. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 6, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 6, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 6, immagine 3 di 3
    • Place the screw, the bolt and connect the cables of the window switch trim panel. Make sure that the wires are pushed in completely.
  7. 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 7, immagine 1 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 7, immagine 2 di 3 1999-2007 Chevrolet Silverado Door Lock Cylinder Replacement: passo 7, immagine 3 di 3
    • Place back the door lock knob with a push. Place the door handle trim, plastic trim, and window switch trim back. Make sure the plastic trim clips connect to the door slots for the plastic trim.
Conclusione
Now, the cylinder door lock is back in its place.
Yurisela Torres
Membro da: 10/20/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 113
Tutti i Tempi: 1,070
