Salta al contenuto principale
1998 Toyota Camry Head and Tail Lights Replacement
Cosa ti serve
  1. 1998 Toyota Camry Head and Tail Lights Replacement, Head and Tail Lights: passo 1, immagine 1 di 2 1998 Toyota Camry Head and Tail Lights Replacement, Head and Tail Lights: passo 1, immagine 2 di 2
    • Make sure your car is turned off and check to make sure the head lights are not on.
  2. 1998 Toyota Camry Head and Tail Lights Replacement: passo 2, immagine 1 di 3 1998 Toyota Camry Head and Tail Lights Replacement: passo 2, immagine 2 di 3 1998 Toyota Camry Head and Tail Lights Replacement: passo 2, immagine 3 di 3
    • Pull the hood lever to unlock the car hood. Pull the safety lever upwards and push the hood of the car open. Put the hood strut (metal rod) to hold the hood up.
  3. 1998 Toyota Camry Head and Tail Lights Replacement: passo 3, immagine 1 di 1
    • Remove the connector (wire) connected to the bulb. Should be on the left side of the car (looking from the front) next to the windshield wiper fluid tube.
  4. 1998 Toyota Camry Head and Tail Lights Replacement: passo 4, immagine 1 di 1
    • Pull out the rubber cover. If maintenance is not done often on the car the rubber cover may get stuck. This can be solved by using tools to push or pry out the rubber cover.
  5. 1998 Toyota Camry Head and Tail Lights Replacement: passo 5, immagine 1 di 1
    • Unhook the metal clip fixing the unusable lightbulb.
  6. 1998 Toyota Camry Head and Tail Lights Replacement: passo 6, immagine 1 di 1
    • Remove the unusable light bulb and place in the new light bulb.
  7. 1998 Toyota Camry Head and Tail Lights Replacement: passo 7, immagine 1 di 1
    • Hook the metal clip back on.
  8. 1998 Toyota Camry Head and Tail Lights Replacement: passo 8, immagine 1 di 1
    • Insert the rubber cover back.
  9. 1998 Toyota Camry Head and Tail Lights Replacement: passo 9, immagine 1 di 1
    • Plug the connector into the new light bulb.
  10. 1998 Toyota Camry Head and Tail Lights Replacement: passo 10, immagine 1 di 3 1998 Toyota Camry Head and Tail Lights Replacement: passo 10, immagine 2 di 3 1998 Toyota Camry Head and Tail Lights Replacement: passo 10, immagine 3 di 3
    • Open the trunk of the car. Remove the 3 screws on the plastic cover using the Phillips #2 screwdriver. All of them will the same length of 19.0 mm, and will not have to be put in back into the exact same positions.
  11. 1998 Toyota Camry Head and Tail Lights Replacement: passo 11, immagine 1 di 1
    • Remove the bulb assembly (twist counterclockwise). The light bulb assembly is located above the center of where the plastic cover (before it was removed).
  12. 1998 Toyota Camry Head and Tail Lights Replacement: passo 12, immagine 1 di 2 1998 Toyota Camry Head and Tail Lights Replacement: passo 12, immagine 2 di 2
    • Pull the light bulb from the socket.
Conclusione
This should take about 15-20 minutes to completely change all the head and tail lights in the car if you are unfamiliar with this process. Once someone is familiar with this it should not take them more than 10 minutes to complete the entire process.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,044
