Salta al contenuto principale
1998-2002 Honda Accord Tail Lights Replacement
Cosa ti serve
  1. 1998-2002 Honda Accord Tail Lights Replacement, Tail Light Bulb Assemblies: passo 1, immagine 1 di 2 1998-2002 Honda Accord Tail Lights Replacement, Tail Light Bulb Assemblies: passo 1, immagine 2 di 2
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: passo 2, immagine 1 di 3 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: passo 2, immagine 2 di 3 1998-2002 Honda Accord Tail Lights Replacement, Panel Tail Lights: passo 2, immagine 3 di 3
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. 1998-2002 Honda Accord Tail Lights Replacement: passo 3, immagine 1 di 3 1998-2002 Honda Accord Tail Lights Replacement: passo 3, immagine 2 di 3 1998-2002 Honda Accord Tail Lights Replacement: passo 3, immagine 3 di 3
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  4. 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: passo 4, immagine 1 di 3 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: passo 4, immagine 2 di 3 1998-2002 Honda Accord Tail Lights Replacement, Trunk Lid Tail Lights: passo 4, immagine 3 di 3
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
  5. 1998-2002 Honda Accord Tail Lights Replacement, Tail Lights: passo 5, immagine 1 di 2 1998-2002 Honda Accord Tail Lights Replacement, Tail Lights: passo 5, immagine 2 di 2
    • Remove the connector at the bottom of the panel tail light assembly.
    • Locate the three 8 mm nuts holding the panel tail light assembly to the car and use an 8 mm socket wrench or box end wrench to remove the them.
  6. 1998-2002 Honda Accord Tail Lights Replacement: passo 6, immagine 1 di 1
    • Remove the panel tail light assembly by pulling it straight away from the car.
    • If you are having troubles removing the light, try wiggling it back and forth as you pull it out.
  7. 1998-2002 Honda Accord Tail Lights Replacement: passo 7, immagine 1 di 3 1998-2002 Honda Accord Tail Lights Replacement: passo 7, immagine 2 di 3 1998-2002 Honda Accord Tail Lights Replacement: passo 7, immagine 3 di 3
    • Remove the three 8 mm hex nuts securing the trunk tail light using a socket wrench or box end wrench.
    • The black nut at the edge of the trunk lid has an extended round end that prevents a standard 8 mm socket from seating fully. You can use a regular socket if you can keep the bit level while rotating, but a deep socket is recommended to prevent stripping.
  8. 1998-2002 Honda Accord Tail Lights Replacement: passo 8, immagine 1 di 1
    • Lift the trunk tail light up from the outer edge, being careful not to break the plastic locator on the inside edge.
Conclusione
Altre 3 persone hanno completato questa guida.
4 Commenti
I Installed led brakes and thay don't flash when I push on the brake that bottom wire is unhooked was wondering if that ran to the brake switch was wondering how to hard wire it will it would work
Nathan - Replica
My tail lights, brake lights stay on even after I have turn the key off and pulled it out of the keyhole. Is there a part that might be broken that could repair this. Any comments I would appreciate them. Thanks oh I did find little pieces on the floor and wondered what that part might be maybe under the drivers side where the spring is
LaDawn Berkey - Replica
I have to take the cable off the battery or it goes dead. And the little part on the floor was kind of like a plastic washer with a little pointed top on it.
Thanks Nathan. The part was broken into pieces. There is a little spring underneath the steering and, back in a little bit that I wondered if it broke off from that, which would make the break stay on.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 46
Tutti i Tempi: 23,676
