Salta al contenuto principale
1998-2002 Honda Accord Distributor Cap Replacement
Cosa ti serve
  1. 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: passo 1, immagine 1 di 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: passo 1, immagine 2 di 3 1998-2002 Honda Accord Distributor Cap Replacement, Distributor Cap: passo 1, immagine 3 di 3
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. 1998-2002 Honda Accord Distributor Cap Replacement: passo 2, immagine 1 di 1
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. 1998-2002 Honda Accord Distributor Cap Replacement: passo 3, immagine 1 di 2 1998-2002 Honda Accord Distributor Cap Replacement: passo 3, immagine 2 di 2
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. 1998-2002 Honda Accord Distributor Cap Replacement: passo 4, immagine 1 di 1
    • Pull the distributor cap away from the engine and set it aside.
  5. 1998-2002 Honda Accord Distributor Cap Replacement: passo 5, immagine 1 di 2 1998-2002 Honda Accord Distributor Cap Replacement: passo 5, immagine 2 di 2
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
Conclusione
Altre 13 persone hanno completato questa guida.
4 Commenti
I need to do this procedure. Have never done this in years. Next time I will change my wires, plugs and now my distributor cap.
Thurman - Replica
Where can I find the part number?
lawendellr - Replica
what about 6 cylinder
ssingam75 - Replica
excellent, thanks for you aportation.
julio cesar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 97
Tutti i Tempi: 68,555
