Salta al contenuto principale
1997 Toyota Camry Stop and Tail Light Bulbs Replacement
Cosa ti serve
  1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: passo 1, immagine 1 di 3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: passo 1, immagine 2 di 3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: passo 1, immagine 3 di 3
    • Open the trunk.
    • Loosen three 15 mm screws using a Phillips #1 screwdriver.
    • Pull the cover clips at the base to remove.
    • Potential for device damage: Do not pull the cover clips prior to unscrewing as the cover clips can break.
    • Remove the cover by folding the cover backwards to expose the bulb assembly.
  2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 2, immagine 1 di 2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 2, immagine 2 di 2
    • Grab the inner light bulb assembly using your thumb and forefinger.
    • Rotate the bulb assembly a quarter turn counterclockwise.
    • Pull it straight outwards until the bulb is displayed.
  3. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 3, immagine 1 di 1
    • While holding the assembly, grab the base of the light bulb with your thumb and forefinger.
    • Pull the bulb away from the assembly until it detaches. Discard the old bulb.
  4. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 4, immagine 1 di 1
    • Grab the new inner tail light bulb 3157 and push it into the bulb assembly.
    • Insert the bulb assembly straight into the socket. Rotate it a quarter turn clockwise to secure it.
  5. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 5, immagine 1 di 1
    • Repeat this process with the outer light bulb assembly using bulb 904.
  6. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 6, immagine 1 di 2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: passo 6, immagine 2 di 2
    • Unfold the cover and place it back over the bulb sockets. Push the three cover clips into their sockets .
    • Screw the three 15 mm screws in with Phillips #1 screwdriver to secure the cover.
Conclusione
Your stop and tail lights have been properly replaced and your replace bulb indicator should be off on your dashboard.
Ivan Navas
Membro da: 02/24/21
138 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 68
Tutti i Tempi: 2,277
