Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Strumenti
Nessun attrezzo specificato.
Parti
  1. Prop up your hood.
    • Prop up your hood.
    • Make sure you prop your hood up with your hood prop rod.
  2. Locate the back of the headlight you plan to replace the bulb in.
    • Locate the back of the headlight you plan to replace the bulb in.
    • This will be directly behind the headlight assembly.
    • If you are replacing your left headlight, you may need to remove the battery to have enough room to do this replacement.
  3. Disconnect the headlight.
    • Disconnect the headlight.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
    • Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
  6. Release the bulb by pushing the metal fastener inward and then moving it upwards. Release the bulb by pushing the metal fastener inward and then moving it upwards.
    • Release the bulb by pushing the metal fastener inward and then moving it upwards.
  7. Remove the bulb.
    • Remove the bulb.
  8. Insert the new bulb. Make sure the metal tabs fit correctly.
    • Insert the new bulb. Make sure the metal tabs fit correctly.
    • I've read that touching the glass on the bulb can shorten the life of the bulb, so try not to do that.
Conclusione
To finish your headlight bulb replacement, follow these instructions in reverse order.
Altre 15 persone hanno completato questa guida.
Chris Opperwall
Membro da: 04/04/2013
1.231 Reputazione
1 Guida realizzata
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
rakslice - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 109
Ultimi 30 Giorni: 362
Tutti i Tempi: 40,234
