Salta al contenuto principale
1997-2003 Chevrolet Malibu Tail Lights Replacement
Cosa ti serve
  1. 1997-2003 Chevrolet Malibu Tail Lights Replacement, Tail Lights: passo 1, immagine 1 di 1
    • Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
    • Unscrew the plastic casings.
  2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 2, immagine 1 di 1
    • Make sure to put some pressure on the tail light itself so it does not fall out when you unscrew it.
    • Unscrew the three plastic wing nuts located behind the tail lights.
  3. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 3, immagine 1 di 1
    • When the tail light assembly comes loose, do not fully remove it because it may damage the connected wires.
    • Carefully pull the tail light away from the car to expose the connected wires.
  4. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 4, immagine 1 di 3 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 4, immagine 2 di 3 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 4, immagine 3 di 3
    • Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
    • Remove the rear panel from the rest of the assembly.
  5. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 5, immagine 1 di 1
    • Do not pull on the bulb, handle it gently because it is fragile.
    • Grab the plastic base of the bulb and gently wiggle it free.
  6. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 6, immagine 1 di 1
    • When handling the new bulbs, avoid touching the glass as much as possible because this can reduce the life of the bulb.
    • Gently push the new bulb into the plastic housing.
  7. 1997-2003 Chevrolet Malibu Tail Lights Replacement: passo 7, immagine 1 di 1
    • After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
    • These bulbs have different functions including blinkers, brake lights, hazard lights, and back-up lights. They will only turn on when the necessary signal is sent.
Conclusione
Altre 4 persone hanno completato questa guida.
Sank Yang
Membro da: 10/03/12
484 Reputazione
5 Guide realizzate
Cal Poly, Team 9-15, Amido Fall 2012 Membro di Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 19,453
