Salta al contenuto principale
1997-2003 Chevrolet Malibu Spark Plugs Replacement
Cosa ti serve
  1. 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: passo 1, immagine 1 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: passo 1, immagine 2 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: passo 1, immagine 3 di 3
    • Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
    • These four bolts should be torqued to 18 ft-lbs when putting the spark plug cover back on.
  2. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 2, immagine 1 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 2, immagine 2 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 2, immagine 3 di 3
    • With a flathead screwdriver remove the ignition coil electrical connector on the right side of spark plug cover.
    • Be careful while disconnecting the ignition coil electrical connector as it may break.
  3. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 3, immagine 1 di 2 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 3, immagine 2 di 2
    • Remove the spark plug cover.
  4. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 4, immagine 1 di 1
    • When working with compressed air, wear safety glasses to protect your eyes from flying debris.
    • Use compressed air to clear any debris from the area around the spark plugs.
    • Any particles that fall into the cylinder could cause serious engine damage.
    • Use a 5/8" spark plug socket with an extension to loosen and remove the spark plugs.
  5. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 5, immagine 1 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 5, immagine 2 di 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 5, immagine 3 di 3
    • Before installing the new spark plugs check that the spark plugs' gap is between 0.048 and 0.052 inches.
    • If it needs to be widened, use a gap setter to increase the size of the gap until it reaches the desired width.
  6. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: passo 6, immagine 1 di 1
    • Wedge the new spark plugs into a 5/8'' spark plug socket.
    • Place the spark plug into the cylinder using the socket and hand tighten the spark plugs as much as possible.
    • Tighten the spark plugs to 13 ft-lbs with a torque wrench.
    • Do not over tighten spark plugs. This could strip out the threaded holes in the head.
Conclusione
To reassemble your device, follow Steps 1-3 in reverse order.
Altre 5 persone hanno completato questa guida.
Sank Yang
Membro da: 10/03/12
484 Reputazione
5 Guide realizzate
Cal Poly, Team 9-15, Amido Fall 2012 Membro di Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 96
Tutti i Tempi: 36,672
