Salta al contenuto principale
1996-1998 Acura TL Stereo Head Unit Replacement
Cosa ti serve
  1. 1996-1998 Acura TL Stereo Head Unit Replacement, Center Dash: passo 1, immagine 1 di 1
    • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
  2. 1996-1998 Acura TL Stereo Head Unit Replacement: passo 2, immagine 1 di 1
    • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
  3. 1996-1998 Acura TL Stereo Head Unit Replacement, Stereo Head Unit: passo 3, immagine 1 di 1
    • Unscrew the four screws from the sides of the deck, circled here.
  4. 1996-1998 Acura TL Stereo Head Unit Replacement: passo 4, immagine 1 di 1
    • Pull the head unit straight out gently until the two wire harnesses are exposed.
  5. 1996-1998 Acura TL Stereo Head Unit Replacement: passo 5, immagine 1 di 1
    • Push down on the tabs and remove the wiring from their blue and white harnesses.
    • These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
    • As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
Conclusione
Altre 2 persone hanno completato questa guida.
Brayden
Membro da: 10/05/12
16 Reputazione
5 Guide realizzate
Cal Poly, Team 18-42, Regan Fall 2012 Membro di Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 Membri
5 Guide realizzate
2 Commenti
Awesome! I got an Acura TL 1998
PROJECT zeroto100 - Replica
Thank you for the guid. Can you please make another about how you put aux into this Stereo Head Unit?
Сергей Твердохлеб - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,181
