Introduzione
This guide will follow up on the removal of the front dash panel removal and show you how to access the actual stereo head unit.
Cosa ti serve
Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
Push down on the tabs and remove the wiring from their blue and white harnesses.
These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
Altre 2 persone hanno completato questa guida.
2 Commenti
Awesome! I got an Acura TL 1998
Thank you for the guid. Can you please make another about how you put aux into this Stereo Head Unit?
