Salta al contenuto principale
Introduzione
This guide will show you have to access the rear speaker located behind the back seat headrest.
Parti
Nessuna parte specificata.
  1. Remove the three screws holding the speaker panel in place.
    • Remove the three screws holding the speaker panel in place.
  2. Disconnect the wiring harness in trunk.
    • Disconnect the wiring harness in trunk.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Slide the speaker panel towards the center of car and pull it out.
    • Slide the speaker panel towards the center of car and pull it out.
  5. Remove the four screws holding the speaker in.
    • Remove the four screws holding the speaker in.
    • Lift the speaker out and removal is complete.
Conclusione
Brayden
Membro da: 05/10/2012
13 Reputazione
5 Guide realizzate
Cal Poly, Team 18-42, Regan Fall 2012 Membro di Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,600
