Salta al contenuto principale
1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement
Cosa ti serve
  1. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: passo 1, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: passo 1, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement, Valve Cover Gasket: passo 1, immagine 3 di 3
    • Pull the lever towards you to release the hood. You should hear a pop release coming from the front of the hood.
    • Push and hold the hood latch with the left hand and pull the hood up with your right hand to open.
    • Lock the hood stand into the two holes to keep the hood up located on the right-hand side of the hood.
    • Check the hood stand is secured and sturdy so that it doesn't collapse onto you.
  2. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 2, immagine 1 di 1
    • Visually inspect for any burns or black spots are usually an indication of an oil leak caused by a bad valve cover gasket.
  3. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 3, immagine 1 di 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery by using the ratchet with a 10 mm socket.
    • Rotate the ratchet counterclockwise to remove the bolts.
    • Place the positive and negative terminal cables away from any contact with the battery or metal components.
    • Avoid contacting the terminal leads; arching/shocking will occur if the two-terminal leads touch each other.
  4. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 4, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 4, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 4, immagine 3 di 3
    • Use tape to label the spark plug wires numbers 1 thru 4.
    • Pull the spark plug wires up or towards your upper body to remove them from the engine valve cover.
    • Twist and pull the air intake breather tube to remove it from the valve cover.
  5. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 5, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 5, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 5, immagine 3 di 3
    • Remove the single 10 mm bolt that is attached to the spark plug fixture mount.
    • Remove the three 10 mm bolts in the front and the two 10mm bolts from the back of the valve cover in a counterclockwise motion.
    • Pull the valve cover up to remove it from the engine and place it aside.
  6. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 6, immagine 1 di 2 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 6, immagine 2 di 2
    • Wipe and clean off the cylinder head surface using a shop towel.
    • Use a flat head screwdriver to help scrape in between areas that are difficult to reach.
  7. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 7, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 7, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 7, immagine 3 di 3
    • Grip the square tab with your fingers and pull up to remove the valve cover gasket.
    • Install the new gasket with the square tab located to the lower right of the valve cover.
  8. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 8, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 8, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 8, immagine 3 di 3
    • Install the valve cover back onto the engine.
    • Bolts will shear if over-tightened.
    • Install the five 10mm bolts onto the valve cover starting with the middle first follow by the outer bolts in an X-pattern fashion.
    • Install the single 10mm bolt with the spark plug wire fixture mount.
    • Install the spark plug wires back into the valve cover in numeric order that it was removed.
    • Install the air intake breather tube.
  9. 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 9, immagine 1 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 9, immagine 2 di 3 1996-2000 Honda Civic Valve Cover Gasket Replacement Valve Cover Gasket Replacement: passo 9, immagine 3 di 3
    • Reconnect the battery cables starting with the black negative cable then the red positive cable.
    • Remove all tapes from spark plug wires.
    • Verify all bolts are installed and secured, then close the hood.
Conclusione
Now that you have successfully installed a new valve cover gasket, the oil-burning into the atmosphere is now gone along with improving the engine's life.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 111
Tutti i Tempi: 3,530
