Salta al contenuto principale
1995-2002 Toyota 4Runner Oil and Oil Filter Replacement
Cosa ti serve
Panoramica Video
  1. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 1 di 1
    • Make sure the engine oil is hot so it can flow out of the engine easily
    • Either drive the vehicle or run the engine for about 5 minutes before starting the oil change.
  2. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 2, immagine 1 di 1
    • Begin with removing the steel guard from underneath the vehicle
    • Start by removing the three 12mm socket bolts located at the front of the guard.
  3. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 3, immagine 1 di 1
    • Remove the two 12mm socket bolts located deep within the front plate.
  4. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 4, immagine 1 di 1
    • Remove the rear bolts, but the steel guard will not fall off because it has hooks attached to the front frame.
  5. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 5, immagine 1 di 1
  6. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 6, immagine 1 di 1
    • With the steel guard removed, locate the engine oil pan and use a 14mm socket wrench to remove the drain plug.
  7. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 7, immagine 1 di 1
  8. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 8, immagine 1 di 1
    • Open the filler cap located in the engine bay, which should indicate the required oil type (5W30)
    • Clean the area around the cap and remove it, but place it back loosely to prevent any dirt from falling into the engine.
  9. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 9, immagine 1 di 1
    • Allow the engine oil to drain for an extended period, such as 30 minutes, to ensure maximum oil removal.
  10. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 10, immagine 1 di 1
    • While the oil is draining, inspect and clean the splash shield and check for any leaks.
  11. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 11, immagine 1 di 1
    • Remove the old engine oil filter by reaching it from the front and coming around the lower radiator hose
    • If the filter is not overtightened, you should be able to remove it by hand.
  12. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 12, immagine 1 di 1
    • Prepare the new engine oil filter by applying a small amount of oil to the rubber gasket.
  13. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 13, immagine 1 di 1
  14. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 15, immagine 1 di 1
    • Reinstall the drain plug with its washer and tighten it using the 14mm socket wrench
    • Be careful not to overtighten it, as it could damage the threads on the oil pan
    • The torque for the drain plug is 33 foot-pounds if you want to use a torque wrench.
  15. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 16, immagine 1 di 1
    • Fill the engine with the recommended 5W-30 engine oil using a funnel
    • Add 4 quarts initially, then gradually add more while checking the dipstick to avoid overfilling.
  16. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 17, immagine 1 di 1
    • Fill the engine with a total of 5.5 US quarts of engine oil, as specified in the manual for an oil change with filter replacement.
  17. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: passo 18, immagine 1 di 1
    • Reinstall the steel guard using the 12mm socket wrench, making sure to apply anti-seize to the bolts for easy removal in the future.
Conclusione
eCuration
Membro da: 05/19/17
376.693 Reputazione
234 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.818 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 84
Tutti i Tempi: 9,791
