Salta al contenuto principale
1994-2001 Acura Integra Door Panel Replacement
Cosa ti serve
  1. 1994-2001 Acura Integra Door Panel Replacement, Door Panel: passo 1, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement, Door Panel: passo 1, immagine 2 di 2
    • Remove the plastic Phillips screw towards the front of the door panel.
    • This screw is part of a two-piece securing mechanism. Do not apply force directly onto the screw head, because it will continue to slip into the plastic clip.
    • Use a flathead screwdriver to remove the plastic clip that holds the screw.
  2. 1994-2001 Acura Integra Door Panel Replacement: passo 2, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement: passo 2, immagine 2 di 2
    • Unscrew the Phillips screw in the bottom of the door panel cup.
    • Lift the cup out of the the door panel.
  3. 1994-2001 Acura Integra Door Panel Replacement: passo 3, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement: passo 3, immagine 2 di 2
    • Insert a very thin flathead screwdriver blade into the small gap towards the rear of the car on the plastic screw cover near the door handle.
    • Unscrew the Phillips screw underneath the screw cover.
  4. 1994-2001 Acura Integra Door Panel Replacement: passo 4, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement: passo 4, immagine 2 di 2
    • Remove the plastic cover at the base of the C-pillar by pulling it directly away from the window.
    • The cover is held in place by a metal clip, so some force will be required to free it.
    • In addition to the metal clip, two small tabs at the bottom of the cover keep it in place. Gently lift the corner of the door panel to remove the tabs from their respective holes in the door.
  5. 1994-2001 Acura Integra Door Panel Replacement: passo 5, immagine 1 di 3 1994-2001 Acura Integra Door Panel Replacement: passo 5, immagine 2 di 3 1994-2001 Acura Integra Door Panel Replacement: passo 5, immagine 3 di 3
    • Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side.
    • Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
  6. 1994-2001 Acura Integra Door Panel Replacement: passo 6, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement: passo 6, immagine 2 di 2
    • Pull the bottom of the door panel away from the door, and lift the entire panel off the door.
    • Do not try to completely remove the door panel yet, as it is still attached by a number of electrical connectors.
  7. 1994-2001 Acura Integra Door Panel Replacement: passo 7, immagine 1 di 3 1994-2001 Acura Integra Door Panel Replacement: passo 7, immagine 2 di 3 1994-2001 Acura Integra Door Panel Replacement: passo 7, immagine 3 di 3
    • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
    • Use the same method described above to remove the connector for the tweeter.
    • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  8. 1994-2001 Acura Integra Door Panel Replacement: passo 8, immagine 1 di 2 1994-2001 Acura Integra Door Panel Replacement: passo 8, immagine 2 di 2
    • Disconnect the power window connector.
    • You may now remove the entire door panel.
Conclusione
Altre 5 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.523 Reputazione
127 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 60
Tutti i Tempi: 20,907
