Salta al contenuto principale
1993-1997 Toyota Corolla Headlight Bulb Replacement
  1. 1993-1997 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • Reach underneath the panel below the steering column and pull the black lever to unlock hood. The lever will have an icon of a car with a propped open hood.
  2. 1993-1997 Toyota Corolla Headlight Bulb Replacement: passo 2, immagine 1 di 1
    • Place two fingers underneath hood but directly on top of Toyota emblem to locate hood latch. Push up with both fingers to unlock latch.
  3. 1993-1997 Toyota Corolla Headlight Bulb Replacement: passo 3, immagine 1 di 1
    • Located right behind the headlight is a red Deutsch connector. Push down on that connector to unplug wiring and rotate unconnected portion counterclockwise, facing from the driver's view, to remove bulb.
  4. 1993-1997 Toyota Corolla Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • With bulb exposed, twist broken bulb counterclockwise to unscrew from electrical connection. Screw in new bulb clockwise and replace back into socket.
  5. 1993-1997 Toyota Corolla Headlight Bulb Replacement: passo 5, immagine 1 di 1
    • Be very careful twisting new bulb into electrical connection as the bulbs are very easily damaged.
Conclusione
Altre 6 persone hanno completato questa guida.
Shane Moore
Membro da: 10/11/14
272 Reputazione
1 Guida realizzata
USF Tampa, Team 1-23, Donnelly Fall 2014 Membro di USF Tampa, Team 1-23, Donnelly Fall 2014
USFT-DONNELLY-F14S1G23
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 10,790
