Salta al contenuto principale
1991-1996 Toyota Camry Oil and Oil Filter Replacement
Cosa ti serve
Panoramica Video
  1. 1991-1996 Toyota Camry Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 1 di 1
    • Locate the oil filter under the exhaust manifold in the front of the vehicle
    • source.
  2. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 2, immagine 1 di 1
    • Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
    • source
    • Be careful not to burn yourself on the hot manifold.
  3. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 3, immagine 1 di 1
    • Unscrew the oil filter and let it drain into the oil drain pan
    • source
    • Make sure the pan is aligned to catch oil from both the filter and drain plug.
  4. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 4, immagine 1 di 1
    • Carefully remove the old oil filter
    • source.
  5. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, immagine 1 di 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, immagine 2 di 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 5, immagine 3 di 3
    • Clean the mating surface where the new filter will be installed
    • Ensure there are no old seals or debris that could affect the new filter's seal
    • source.
  6. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 6, immagine 1 di 1
    • Install the new oil filter by hand tightening it
    • source.
  7. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 7, immagine 1 di 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 7, immagine 2 di 2
    • Move to the oil drain plug location and remove it using the 14mm socket and ratchet
    • source
    • Let the oil drain into the pan
    • source.
  8. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 8, immagine 1 di 1
    • Replace the old gasket on the drain plug with a new one, if necessary
    • source.
  9. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 9, immagine 1 di 2 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 9, immagine 2 di 2
    • Tighten the drain plug using the 14mm socket
    • source
    • Clean up any excess oil
    • source.
  10. 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, immagine 1 di 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, immagine 2 di 3 1991-1996 Toyota Camry Oil and Oil Filter Replacement: passo 10, immagine 3 di 3
    • Refill the engine with 5W-30 oil using a funnel
    • source
    • This engine should take about five quarts
    • source
    • Be careful when filling the oil, as there is a plate just under the fill opening that can cause spills
    • source
    • Tilt the funnel to ensure the oil goes into the engine
    • source.
Conclusione
eCuration
Membro da: 05/19/17
376.693 Reputazione
234 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.732 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 9,787
