Note: disconnect your battery BEFORE anything else! This procedure is for models WITHOUT airbags!
  • Note: disconnect your battery BEFORE anything else! This procedure is for models WITHOUT airbags!
  • First, pull off your horn button and remove the horn wire by pushing in and twisting the plastic keeper.
Aggiungi Commento
There are six "torx head" screws that hold the steering wheel to the steering wheel hub. It is NOT necessary to remove these, but it does make the job easier.
  • There are six "torx head" screws that hold the steering wheel to the steering wheel hub. It is NOT necessary to remove these, but it does make the job easier.
Aggiungi Commento
  • Remove the steering shaft nut and pull off the steering hub. A steering wheel puller may be required. Use caution as the steering hub may pop loose. Next, remove the two "torx head" screws behind the steering hub that hold the two plastic covers together.
Aggiungi Commento
  • The top plastic cover should pull off with a little persuasion.
Aggiungi Commento
  • Use locking pliers to unscrew the tilt-adjusting lever. TIP: Wrap a shop towel or dish cloth around the lever to keep from scratching it.
Aggiungi Commento
  • Remove the three "torx hed" screws holding the bottom plastic cover to the steering column. The cover should then fall off.
Aggiungi Commento
  • The first picture is what you should see while sitting in the car correctly. Lean over to find and remove the two "torx head" screws on the left-hand side of the ignition assembly.
Aggiungi Commento
  • Use a flat head screwdriver to make sure the new switch is good (reconnect battery and turn the switch in either direction as if to turn the vehicle on then start then off. It should turn smoothly and only kick back to the on position. After testing the new switch, disconnect the battery again. Take note of the tab on the case of the switch.
Aggiungi Commento
  • Tab A goes into slot B, marked in the photo. Also note that just above the red circle is the end of the ignition lock cylinder in the off position. If yours is not in the off position, it should be.
Aggiungi Commento
  • Putting everything back together is the opposite removal. It should be fairly easy.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
islindsey
Membro da: 22/06/2012
202 Reputazione
1 Guida realizzata
How to change out the key switch 94 Cavalier
eddie Richardson - Replica
Quick and easy fix! Thanks!
Terry Manning - Replica
Where can get a replacement ignition switch? Do stores carry them??
Forrest Sutton - Replica
how do you get the switch cylinder out of column
Mark A Branner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 110
Tutti i Tempi: 7,513
