Salta al contenuto principale
1986 Pontiac Fiero Headlight Motor Gear Replacement
Cosa ti serve
    1. 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: passo 1, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: passo 1, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: passo 1, immagine 3 di 3
      • Make sure the car is turned off for this process.
      • Open the hood and prop it open for easy access.
      • Locate the battery and two terminals, black (-) and red (+).
      • Use a wrench to loosen the nut and disconnect the negative (black, minus sign) terminal, apply the same method to the positive (red, plus sign) terminal.
      • Disconnect the headlight from its spot by removing the four bolts connected to it with a 10mm socket and wrench.
      • There are two bolts on the top and two bolts on the bottom, use the socket to hold one end of each bolt in place while using the wrench to loosen.
      • Disconnect the headlight power cable that leads to the lightbulb, then remove the headlight from its spot while disconnecting the remaining wires.
      • There should be a tab or clip to disconnect the headlight power cable that leads to the lightbulb.
      Chiedi a FixBot
      Aggiungi Commento
    2. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 2, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 2, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 2, immagine 3 di 3
      • You should see a blue and red wire connected to the battery.
      • Disconnect the blue wire that leads to the motor and the red wire harness that leads to the headlight relay.
      • Now, you can move the headlight to a clean working space for the next steps.
      Chiedi a FixBot
      Aggiungi Commento
    3. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 3, immagine 1 di 1
      • Remove the headlight from the housing frame.
      • Remember or take a picture of the arm orientation for when you need to put everything back in place.
      Chiedi a FixBot
      Aggiungi Commento
    4. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 4, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 4, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 4, immagine 3 di 3
      • On the motor, there should be three screws securing it to the headlight casing.
      • Remove the motor from the headlight by removing those three screws around the motor as well as the screws on the motor arm.
      • Use the 10mm wrench for the screws on the casing and for the nut on the arm.
      • Use the 1/4" Allen wrench to hold the arm screw in place.
      Chiedi a FixBot
      Aggiungi Commento
    5. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 5, immagine 1 di 2 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 5, immagine 2 di 2
      • Remove the motor from the headlight casing and remove the last connection from the relay.
      Chiedi a FixBot
      Aggiungi Commento
    6. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 6, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 6, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 6, immagine 3 di 3
      • To remove the nut on the arm, turn the wrench counter-clockwise.
      • Remove the arm with gentle but firm pressure, if the arm will not budge, hit it with a mallet/hammer to slide it off the rod.
      Chiedi a FixBot
      Aggiungi Commento
    7. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 7, immagine 1 di 2 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 7, immagine 2 di 2
      • Remove the screws around the motor casing using the 8 mm wrench and a Phillips screwdriver.
      • If the motor is still factory sealed, take a 1/8" drill bit and drill through the rivets holding the casing closed.
      • Remove the casing.
      Chiedi a FixBot
      Aggiungi Commento
    8. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 8, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 8, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 8, immagine 3 di 3
      • When removing the cover you should see two gears: one metal and one plastic. There should also be a metal lever in between the gears.
      • Remove both of the gears and the lever.
      • Remember their orientation or take a picture for when you need to put everything back in place.
      Chiedi a FixBot
      Aggiungi Commento
    9. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 9, immagine 1 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 9, immagine 2 di 3 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 9, immagine 3 di 3
      • The plastic gear may have plastic shavings or dried grease on it so you will need to clean out the casing.
      • The lever may have leftover rubber spacing coating on it, if left unchecked the residue will cause problems so you will need to clean this.
      Chiedi a FixBot
      Aggiungi Commento
    10. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 10, immagine 1 di 2 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 10, immagine 2 di 2
      • Put new grease on a new plastic gear, then replace the old plastic gear in the motor.
      Chiedi a FixBot
      Aggiungi Commento
    11. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 11, immagine 1 di 2 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 11, immagine 2 di 2
      • Put new rubber spacers in the far corners of the inside of the plastic gear.
      Chiedi a FixBot
      Aggiungi Commento
    12. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 12, immagine 1 di 1
      • Put in the lever and make sure it fits snugly.
      • Once that is in place, put the metal gear back on.
      Chiedi a FixBot
      Aggiungi Commento
    13. 1986 Pontiac Fiero Headlight Motor Gear Replacement: passo 13, immagine 1 di 1
      • Put a resealing agent on the edges of the motor and close the casing again.
      • When closing the case there is a seal inside the top of the motor casing. Use needle nose pliers or a flathead screwdriver to hold it in place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Hopefully these steps worked for you and your headlight is working like new! If you're still having trouble just leave a comment either on a specific step or for the full guide, someone should be able to help you out. If not, their are plenty of helpful guides and forums out there to point you in the right direction. Nice work!
Sevin
Membro da: 02/24/25
241 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 33
Tutti i Tempi: 377
