Introduzione
Replace the spark plugs in your Volvo 240 every 60,000 to keep it running in tip-top shape. Though there were a number of engine choices for the Volvo 240, the procedure below is applicable to all SOHC inline-4 engines.
There are many aftermarket companies who manufacture spark plugs that promise to increase performance and fuel economy. However, the most reliable and longest-lasting plugs are usually OEM plugs from the car's manufacturer.
Cosa ti serve
The four spark plugs are located on the passenger side of the engine near the exhaust manifold. Replace the spark plugs one at a time.
Before removing the spark plug, used compressed air to clear the area around the plug of any dirt or debris.
Place a 13/16" spark plug socket over the spark plug and make sure the spark plug is securely seated in the socket.
Gently loosen the spark plug by slowly turning the wrench counterclockwise. Once the spark plug is free, remove it and set it aside.
In order to fire correctly, the gap between the two electrodes on the new spark plug must be properly set. Use a gap tool to adjust the side electrode (the one that hovers over the center electrode) until the gap is between 0.028" and 0.032".
Before installing the spark plug, cover the threads with a thin layer of anti-seize compound. This will ensure that the spark plugs come out easily at the next change.
Place the spark plug into the spark plug socket until it is firmly seated and reinstall it into the engine. Work slowly to avoid cross-threading. Tighten the plug until it is finger-tight and then provide an additional 1/2 turn with the wrench (about 20 ft-lbs).
Before placing the boot back on the spark plug, spread a layer of dielectric grease on the opening of the boot. This will keep moisture and corrosion away from the spark plug, as well as make the boot easier to remove in the future.
Place the boot over the plug and push it down until it snaps into place.
Repeat this procedure for the other three spark plugs, and you're done!
Feel the power with your new spark plugs!
Altre 3 persone hanno completato questa guida.
