Salta al contenuto principale
1986-1993 Volvo 240 Spark Plug Wires Replacement
Cosa ti serve
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: passo 1, immagine 1 di 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: passo 2, immagine 1 di 2 1986-1993 Volvo 240 Spark Plug Wires Replacement: passo 2, immagine 2 di 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Conclusione
Install your new spark plug wires in the same manner that you removed the old ones.
Altre 2 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.503 Reputazione
127 Guide realizzate
2 Commenti
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Replica
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,019
