Salta al contenuto principale
1986-1993 Volvo 240 Front Springs Replacement
Cosa ti serve
  1. 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: passo 1, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: passo 1, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement, Front Springs: passo 1, immagine 3 di 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or tire iron to remove the five 19 mm lug nuts from the front wheel.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Springs Replacement: passo 2, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 2, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 2, immagine 3 di 3
    • Use a socket wrench or impact gun to remove the 15 mm nut on the front sway bar endlink.
  3. 1986-1993 Volvo 240 Front Springs Replacement: passo 3, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 3, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 3, immagine 3 di 3
    • The front brake lines are attached to the body by a small bracket near the strut.
    • Grab the front edge of the bracket with a pair of locking pliers.
    • Without the locking pliers to hold the bracket in place, it may twist back and forth. This twisting could fracture the rigid brake lines.
    • Remove the 12 mm bolt that holds the bracket in place with a socket wrench.
  4. 1986-1993 Volvo 240 Front Springs Replacement: passo 4, immagine 1 di 2 1986-1993 Volvo 240 Front Springs Replacement: passo 4, immagine 2 di 2
    • Use a socket wrench or impact gun to remove the 19 mm tie rod end nut.
  5. 1986-1993 Volvo 240 Front Springs Replacement: passo 5, immagine 1 di 2 1986-1993 Volvo 240 Front Springs Replacement: passo 5, immagine 2 di 2
    • Place a tie rod end puller over the exposed threads of the tie rod end and turn the puller with a socket wrench to push the tie rod end out of the steering knuckle.
  6. 1986-1993 Volvo 240 Front Springs Replacement: passo 6, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 6, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 6, immagine 3 di 3
    • The ball joint is held to the control arm by three 18 mm bolts.
    • Remove the bottom two nuts with a breaker bar or long wrench.
    • Place a breaker bar over the gold nut on the bottom of the control arm.
    • The breaker bar alone will not be able to loosen the nut, since the bolt is free to rotate.
    • Place an 18 mm box end wrench over the bolt on top of the control arm.
    • Turn the breaker bar and the wrench in their respective counterclockwise directions to loosen and remove the third ball joint-to-control arm bolt.
  7. 1986-1993 Volvo 240 Front Springs Replacement: passo 7, immagine 1 di 1
    • Place a jack underneath the ball joint to support it once you remove the 3 ball joint-to-control arm bolts.
  8. 1986-1993 Volvo 240 Front Springs Replacement: passo 8, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 8, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 8, immagine 3 di 3
    • Open the hood and locate the three strut mounting bolts on the strut tower.
    • Make an alignment mark on the shoe at the dimple in the top of the strut tower before removing the mounting nuts.
    • Use a ratcheting socket wrench or impact wrench with a 13 mm deep socket to remove the three nuts.
  9. 1986-1993 Volvo 240 Front Springs Replacement: passo 9, immagine 1 di 1
    • Slowly lower the jack and guide the strut assembly down and out of the car.
  10. 1986-1993 Volvo 240 Front Springs Replacement: passo 10, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 10, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 10, immagine 3 di 3
    • Place spring compressors on opposite sides of the spring.
    • Make sure you are using spring compressors that are meant for MacPherson struts. Internal-type spring compressors will not work.
    • Alternate tightening the spring compressors evenly until you are able to move the entire spring up and down.
  11. 1986-1993 Volvo 240 Front Springs Replacement: passo 11, immagine 1 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 11, immagine 2 di 3 1986-1993 Volvo 240 Front Springs Replacement: passo 11, immagine 3 di 3
    • Use an impact wrench to remove the 24 mm nut at the top of the strut assembly.
    • Remove the strut mount from the strut assembly.
  12. 1986-1993 Volvo 240 Front Springs Replacement: passo 12, immagine 1 di 2 1986-1993 Volvo 240 Front Springs Replacement: passo 12, immagine 2 di 2
    • Remove the upper spring seat and pull the spring off the strut assembly.
    • If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
    • When installing new springs you will need to compress them with the spring compressors before placing them on the strut assembly.
    • If you are reinstalling the same springs you may keep the compressors in place until it is time to reassemble the suspension.
Conclusione
Altre 4 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.580 Reputazione
127 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,635
