Salta al contenuto principale
1986-1993 Volvo 240 Distributor Cap Replacement
Cosa ti serve
  1. 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: passo 1, immagine 1 di 2 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: passo 1, immagine 2 di 2
    • The distributor cap is located next to the engine and has all of the spark plug wires connecting to it.
    • Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
  2. 1986-1993 Volvo 240 Distributor Cap Replacement: passo 2, immagine 1 di 3 1986-1993 Volvo 240 Distributor Cap Replacement: passo 2, immagine 2 di 3 1986-1993 Volvo 240 Distributor Cap Replacement: passo 2, immagine 3 di 3
    • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
    • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
    • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  3. 1986-1993 Volvo 240 Distributor Cap Replacement: passo 3, immagine 1 di 3 1986-1993 Volvo 240 Distributor Cap Replacement: passo 3, immagine 2 di 3 1986-1993 Volvo 240 Distributor Cap Replacement: passo 3, immagine 3 di 3
    • Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
    • Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
    • Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
  4. 1986-1993 Volvo 240 Distributor Cap Replacement: passo 4, immagine 1 di 2 1986-1993 Volvo 240 Distributor Cap Replacement: passo 4, immagine 2 di 2
    • Use a flathead screwdriver to release the clip securing the distributor cap.
    • Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Remove the old distributor cap.
    • When installing the new distributor cap, don't forget to reconnect the center ignition coil wire.
Conclusione
Altre 2 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
150.529 Reputazione
127 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 42
Tutti i Tempi: 6,583
