Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
  1. Lift the bottom of the shift boot to expose the shifting socket. Use snap ring pliers to remove the circlip securing the shifter to its socket.
    • Lift the bottom of the shift boot to expose the shifting socket.
    • Use snap ring pliers to remove the circlip securing the shifter to its socket.
  2. Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever. Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
    • Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
    • Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
    • If the pin won't readily come free, try jiggling the shifter while you pull the pin.
  3. Remove the shift lever by pulling it straight up. Remove the plastic bushing in the bottom of the shifter socket.
    • Remove the shift lever by pulling it straight up.
    • Remove the plastic bushing in the bottom of the shifter socket.
  4. Remove the 6 nuts and bolts securing the drive shaft to the guibo and the back side of the transmission.
    • Remove the 6 nuts and bolts securing the drive shaft to the guibo and the back side of the transmission.
    • Only four nuts and bolts are visible and marked in the first picture. The others are hidden on the other side of the drive shaft.
    • Take note of how the bolts, washers and guibo are positioned. They are required to go back in the same way.
  5. Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed. Remove the 4 bolts securing the drive shaft support. Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
    • Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed.
    • Remove the 4 bolts securing the drive shaft support.
    • Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
    • Slowly lower the drive shaft and separate it from the transmission.
    • Remove the guibo and metal separator plate.
    • The separator may not come out with drive line and will be in the transmission.
  6. Remove the bolts securing the transmission to the engine and to the starter. Support the transmission so it doesn't fall when the final support is removed. Generally, a jack is recommended for this.
    • Remove the bolts securing the transmission to the engine and to the starter.
    • Support the transmission so it doesn't fall when the final support is removed.
    • Generally, a jack is recommended for this.
    • Remove the four bolts securing the transmission support to the chassis.
    • Lower the transmission out of the car.
    • In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
  7. Remove the 6 allen bolts securing the pressure plate to the flywheel. Remove the pressure plate.
    • Remove the 6 allen bolts securing the pressure plate to the flywheel.
    • Remove the pressure plate.
  8. Remove the clutch by pulling it straight away from the flywheel.
    • Remove the clutch by pulling it straight away from the flywheel.
    • When reinstalling, use a centering tool like the one shown here.
Conclusione
Phillip Takahashi
Membro da: 22/08/2011
83.061 Reputazione
87 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,002
