Cosa ti serve
First, disconnect the battery.
Note: Always take the negative terminal off first, then the positive terminal.
General Tip: After disconnecting the battery, let the car sit for about 10 minutes. This will allow any residual energy left in the system to settle and it is good practice for any job you are completing.
Unlatch the two clasps, as outlined in the image.
Loosen the screw on the metal band, using a flathead screwdriver.
