1. Firstly Disconnect  battery
    • Firstly Disconnect battery
      • Always take the negative terminal off first.
      • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Unlatch the 2 clasps.
    • Unlatch the 2 clasps.
    • Loosen screw on metal band.
    • Disconnect electronic sensor.
    • Press on the 2 latches, pulling the cable away from sensor.
    • Disconnect hose from MAFS.
    • Remove MAFS.
    • Steps 4-6 are for cleaning only.
    • Spray MAFS cleaner along direction of travel, shown by arrow.
    • Clean electronic coupling with electronics cleaner.
    • Inject conducting lubricant into MAFS electronic coupling.
    • Re attach MAFS to air filter housing and intake hose.
    • Tighten screw on metal band.
    • Latch clasps on either side of MAFS.
    • Re attach electronic cable to MAFS.
Conclusione
Isaac Nitschke
Membro da: 11/10/2010
61 Reputazione
5 Guide realizzate
Cal Poly, Team 3-28, Regan Fall 2010 Membro di Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Membri
9 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 8,036
