Salta al contenuto principale
1922 GE AOU Fan Power cord Replacement
Cosa ti serve
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: passo 1, immagine 1 di 2 1922 GE AOU Fan Power cord Replacement, Power cord: passo 1, immagine 2 di 2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: passo 2, immagine 1 di 1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: passo 3, immagine 1 di 1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: passo 4, immagine 1 di 1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: passo 5, immagine 1 di 1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: passo 6, immagine 1 di 1
    • Remove the switch and set it aside, then pull the wire through the grommet.
Conclusione
Elias Dorna
Membro da: 06/08/16
125 Reputazione
1 Guida realizzata
Texas Tech, Team 3-5, Rauch SU 2016 Membro di Texas Tech, Team 3-5, Rauch SU 2016
TTU-RAUCH-SU16S3G5
2 Membri
1 Guida realizzata
Un commento
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,731
