Salta al contenuto principale
12-String Takamine G Series Guitar String Replacement
Cosa ti serve
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, immagine 1 di 3 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, immagine 2 di 3 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, immagine 3 di 3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: passo 2, immagine 1 di 2 12-String Takamine G Series Guitar String Replacement: passo 2, immagine 2 di 2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: passo 3, immagine 1 di 2 12-String Takamine G Series Guitar String Replacement: passo 3, immagine 2 di 2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: passo 4, immagine 1 di 3 12-String Takamine G Series Guitar String Replacement: passo 4, immagine 2 di 3 12-String Takamine G Series Guitar String Replacement: passo 4, immagine 3 di 3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: passo 5, immagine 1 di 1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: passo 6, immagine 1 di 3 12-String Takamine G Series Guitar String Replacement: passo 6, immagine 2 di 3 12-String Takamine G Series Guitar String Replacement: passo 6, immagine 3 di 3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: passo 7, immagine 1 di 2 12-String Takamine G Series Guitar String Replacement: passo 7, immagine 2 di 2
    • Turn the tuning peg counterclockwise to tighten the string.
Conclusione
Rey Navarro
Membro da: 09/27/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 187
