Salta al contenuto principale
1 - Kettle - The different functions
  1. 1 - Kettle - The different functions, What are the functions of a kettle?: passo 1, immagine 1 di 2 1 - Kettle - The different functions, What are the functions of a kettle?: passo 1, immagine 2 di 2
    • The kettle is a kitchen utensil used to bring a liquid to a boil. Electric kettles, which are the subject of this study, have a built-in heater.
    • The most common models are the cordless kettles: the kettles are placed on a base (see photo) connected to an electrical outlet, during the heating phase. The container can then be detached from the base and used as an ordinary container.
    • The operation of the electric kettle is based on the Joule effect. The kettles are equipped with a heating resistor in the form of a ring-shaped tube. The current, when it passes through the resistor, causes an increase in the thermal energy of the ring: the water is heated by heat transfer.
    • To learn more about the Joule effect, visit this site. See also the definition of a "kettle" on Wikipedia
  2. 1 - Kettle - The different functions, Description: passo 2, immagine 1 di 3 1 - Kettle - The different functions, Description: passo 2, immagine 2 di 3 1 - Kettle - The different functions, Description: passo 2, immagine 3 di 3
    • Our study is of the Moulinex brand model AC10-10S011. It is 1100W.
    • The device consists of a base 1 and a container 2. The base is equipped with a power cord. It is equipped with a device 3 which ensures the electrical continuity with the heating resistor which is in the container. This device is secured to avoid any contact with the electrical conductors.
    • In the tank is a heating element 4. A switch allows to start and stop the heating. This kettle is also equipped with an automatic stop when the water has reached the right temperature.
Conclusione
We now know what a kettle is and what its different functions are. We can move on to the study of its operation in the following guide: "a kettle, how does it work?"“Kettles, how do they work?”
Altre 9 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
shingle ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Atelier Soudé
Membro da: 12/13/18
4.642 Reputazione
18 Guide realizzate
Atelier Soudé Membro di Atelier Soudé
Local Repair Groups
5 Membri
43 Guide realizzate
1Commento della guida
Hi evry bary 'i m for algeria and i want working whith you so if you ar iteressed send me a messaga message please
Belmokdad Idir - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 85
Tutti i Tempi: 5,055
